PEX In Attic - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2014, 10:13 PM   #16
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
Originally Posted by Davejss View Post
I would just slide on some pipe insulation and forget about it. If you were a few states further north I'd be concerned.
I think this is the best advice so far.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 01-17-2014, 08:48 AM   #17
Originally Posted by jeffnc View Post
I don't understand what you mean by no way to shut it off. It has a shutoff at the refrigerator, right? It's not normal to go around putting shut off valves between the source and the fixture, except at the fixture itself, and one main somewhere in the house. An exception would be a PEX home run system with a main manifold, but a normal copper system doesn't have this, so no reason you should require it.
Or am I misunderstanding you?
Yes there is a shut off behind the fridge. But I would have preferred to be able turn it off at the supply end in the event of a problem.
gbchriste is offline   Reply With Quote
Insulation in the attic when the furnace is up there Jimmybrp Insulation 2 12-11-2011 02:26 PM
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-04-2011 11:17 PM
Can I mount a window A/C into the wall, exhausting to the attic? Greg2230 HVAC 2 06-01-2010 08:56 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
