Pex In Attic - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2012, 04:36 PM   #1
Pex in attic
I live in Florida and was reading about PEX on one of the web sites, it said not to use PEX in the attic because of the heat.
Any southerners had good or bad experiences with PEX in hot attics?
Frank
Frankly is offline   Reply With Quote
Old 03-17-2012, 05:04 PM   #2
MarginallyQualified
Rewards Points: 2,464
Pex or not... you really shouldn't put ANY water pipes into an attic.
Well, not unless the INTENTION is to make a water heater out of it.
Old 03-17-2012, 05:09 PM   #3
PEX in attic
I don't have basement or crawlspace, house is on concrete slab. how would u run new piping?
Frank
Old 03-17-2012, 05:18 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
Why are you needing to replace or repipe your home?
If worst comes to worst then I would build a chase through the house on the ceiling and run the pipe, start pulling sheetrock and run pipe or start busting concrete and run pipe but not in the attic.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-17-2012, 07:30 PM   #5
Rewards Points: 636
i have seen someone put tall crown molding up to hide where they ran new water lines due to concrete and copper issue
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-17-2012, 08:35 PM   #6
Homerepairguy's Avatar
Rewards Points: 998
I've read that in Florida, there can be a few nights each winter that gets below freezing. If that's true where you live, will you be able to prevent pipes in your attic from freezing?
HRG
Homerepairguy is offline   Reply With Quote
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-04-2011 11:17 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
