Old 01-13-2012, 09:09 PM   #1
Pex
What is everyone's opinion on using Pex for supply lines? My house which was constructed in 1991 has it and I was planning on using it again but getting the new stuff since I read that it's different and improved. Didn't find any other threads talking about it when I searched.
REXAMUS is offline   Reply With Quote
Old 01-13-2012, 09:14 PM   #2
Pex
If your lines are gray, there not pex there Quest.
There has been no problums with Pex, but there is class actions suites againt Quest.
For a short time there was trouble with some Zern brand fittings for Pex. There's lot of other companys that now make the brass fittings that work fine.
http://www.zurnclassaction.com/?gcli...FYFx4Aoddy2EnQ
ben's plumbing (01-13-2012)
Old 01-13-2012, 09:16 PM   #3
Pex
pex has not had any problems that I know of ..as joe said quest has..pics of your pipe would help to identify what you have
Old 01-13-2012, 09:21 PM   #4
Pex
Here is a pic of some of it that went to the shower before I tore it apart.
Old 01-13-2012, 11:01 PM   #5
call me E
TheEplumber's Avatar
Pex
That is quest pipe. Repipe with PEX- ASAP
Old 01-13-2012, 11:10 PM   #6
Pex
yep that is quest.....get rid of it ....all of it ....
Old 01-14-2012, 12:33 AM   #7
Persona Non Grata
VIPlumber's Avatar
Pex
That particular type of pipe was/is known as Poly B and the fittings are prone to failure. Get rid of ALL the pipe & fittings, especially those hidden in the walls. Too many stories to tell about clients coming home only to find leak(s) as the fittings failed.
VIPlumber is offline   Reply With Quote
Old 01-14-2012, 07:18 AM   #8
JOATMON
ddawg16's Avatar
Pex
Makes me glad I have all copper.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
