Perplexing Plumbing Issue. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2013, 11:28 AM   #1
Perplexing plumbing issue.
Got a spare bathroom on my house that was added by the owner a few years before I bought the house (the house was built in the 1940s). It gurgles when lots of water is ran elswhere in the house. Plumber told me it was not properly vented. Recently, however, water from the washer seeps up through the drain on the shower and on the toilet. Also, I have a ~10 foot tall vertical cast iron pipe on the outside of the hosue on the spare bathroom wall. No cap on top and a 2 inch hole cut at the bottom. Recently, water with toilet paper and washer water has been coming out.
I am at a lost. Plumber has been no help. Thoughts?
P.S. Thanks in advance, so glad I found this forum, so much good info!
MuskogeeZeke is offline   Reply With Quote
Old 02-04-2013, 11:38 AM   #2
Rewards Points: 31
Sounds to me like you have a clog downstream from your (cast iron) vent.
I would snake it and see if that fixes your other issues. But any plumber would do that too, so maybe I am missing something?
Queso Bandit is offline   Reply With Quote
Old 02-04-2013, 11:45 AM   #3
Re
Well I had them snake it a year ago and removed some clogging. It didn't start backing up again until recently. Would some standard drain cleaner work?
Also, any idea why that vertical vent stack thing would ahve a 2 inch hole cut in it at the bottom?
Old 02-04-2013, 11:53 AM   #4
Rewards Points: 31
just a guess, since I don't really understand your setup...
I had a pipe that needed to be snaked, but there wasn't an accessible cleanout. The plumber just took a cutting wheel and cut a hole to run the snake through. It should probably be covered with a rubber coupling.
I never seem to have luck with draino but I guess there's a small chance it could work?
Old 02-04-2013, 11:56 AM   #5
MarginallyQualified
Rewards Points: 2,464
Originally Posted by MuskogeeZeke View Post
Got a... house was built in the 1940s).
10 foot tall vertical cast iron pipe on the outside... water with toilet paper and washer water has been coming out.
In order for plumbers to be a help they need to be paid.
In this case I'll peg your needed help (dig 'em up and re-pipe)
at about 10 grand (that might include the new water line too).
Old 02-04-2013, 12:01 PM   #6
Well assuming I haven't paid the plumber (I have every fluffing time he came out) is rather insulting
And three years ago when I bought the house I had them dig up and replace the line running from my house to the city sewage
Old 02-04-2013, 12:07 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 682
Previous post is right about the hole. It shows signs of previous issues in your sewer line.
Did they replace all of it or just do a spot repair? Did they replace the city stub or just up to that point?
Old 02-04-2013, 12:17 PM   #8
Thanks. Rubber coupling isn't a bad idea. At least fix that problem.
I was trying to avoid having them come out and snake it again, but guess I'm gonna have too. Oh well.
They mentioned the lack of proper venting, would that cause the issue?
Old 02-04-2013, 12:17 PM   #9
They replace the hole thing ($5k). As far as the city stub, I'm not sure...
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 04:06 AM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 09:12 PM
Toilet Plumbing Issue jgb Plumbing 0 04-29-2010 11:09 AM
Advice/thoughts on plumbing issue mrmagoo_83 Plumbing 10 03-26-2010 08:43 AM
Plumbing Issue construction wife Plumbing 3 05-25-2008 11:42 AM
