Old 04-29-2013, 09:34 PM   #1
pedestal sink - leak between j bend and trap arm
we purchased a new faucet for our half bath that has a pedestal sink. the biggest challenge with this pedestal sink is that the pedestal isn't open all the way (think 2 holes with a bit of porcelain between), and the tailpipe slip nut is covered by that bit of porcelain (and no obvious way to tighten). so to get around this, i've decided to work on the plumbing without the pedestal. once i'm leak free, i'll disconnect after the ptrap and re-tighten there.
my problem is that there is always a leak between the j bend and trap arm. the tailipe is plastic (new), j bend is chrome (new), and trap arm (original) looks to be chrome. i've purchased a new j bend, and am using a nylon washer for the tailpipe. the reason i purchased the new j bend is that the original washer was all pitted and dried out. i couldn't find a new flat rubber washer (original), so i figured a new j bend with a rubber beveled washer would be best.
i can't tell much about the leak, but it does appear that it comes from the top of the slip nut on the trap arm. also, i'm not sure if the existing trap arm would be compatible with a beveled washer, but it seems to fit snug. i haven't used any goop, paste, mud, caulk, gunk, etc. and am not sure if i should.
any suggestions on what to try or do next? the only thing i'm worried about is that once the plumbing is leakfree, i'll need to disassemble to fit around the pedestal.
thanks for your help!
hinkbot is offline   Reply With Quote
Old 04-29-2013, 09:46 PM   #2
call me E
TheEplumber's Avatar
I'm thinking you need a flat rubber washer at the j-bend
Old 04-29-2013, 10:11 PM   #3
would i need a j bend that supports a flat washer too then?
The Following User Says Thank You to hinkbot For This Useful Post:
Javiles (04-29-2013)
Old 04-29-2013, 10:16 PM   #4
Master Plumber
Javiles's Avatar
plastic and chrome will not seat properly
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 04-29-2013, 10:18 PM   #5
call me E
yup- either match the old jbend or get new ptrap
Old 04-29-2013, 10:41 PM   #6
Roofmaster
Check the P trap for a small rib where they extruded the plastic, and sand it off with Emory Cloth. I personally hate those nylon washers, they simply do not conform like rubber does.
" A lot of men build things, and a lot of things fall down "
Old 04-30-2013, 08:14 AM   #7
I would use all chrome or all plastic. I prefer chrome for a pedestal sink because the piping is visible. Use some plumber's grease when putting the pieces together and you shouldn't have any leaks.
Old 04-30-2013, 08:40 AM   #8
Average Joe/ex-Navy IC3
gregzoll's Avatar
Can you please post pictures. If it sits on a pedestal, you can lift the bowl enough, you can pull the pedestal away, unless someone bolted or glued that to the floor, then placed the sink on top, which I cannot see them doing.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Connecting brass trap to cast iron (Noob) acr2001 Plumbing 7 08-22-2012 01:37 AM
Seeking help with clogged bathroom sink drain dwlodyka Plumbing 20 03-14-2012 11:36 AM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 01:39 PM
Please help with p trap (pics) techprincesse Plumbing 12 06-03-2011 04:17 PM
Pedestal Sink Drain Meridius Plumbing 9 11-11-2010 01:19 PM
