-   -   pedestal sink - leak between j bend and trap arm (http://www.diychatroom.com/f7/pedestal-sink-leak-between-j-bend-trap-arm-178406/)
hinkbot 04-29-2013 08:34 PM
we purchased a new faucet for our half bath that has a pedestal sink. the biggest challenge with this pedestal sink is that the pedestal isn't open all the way (think 2 holes with a bit of porcelain between), and the tailpipe slip nut is covered by that bit of porcelain (and no obvious way to tighten). so to get around this, i've decided to work on the plumbing without the pedestal. once i'm leak free, i'll disconnect after the ptrap and re-tighten there.
my problem is that there is always a leak between the j bend and trap arm. the tailipe is plastic (new), j bend is chrome (new), and trap arm (original) looks to be chrome. i've purchased a new j bend, and am using a nylon washer for the tailpipe. the reason i purchased the new j bend is that the original washer was all pitted and dried out. i couldn't find a new flat rubber washer (original), so i figured a new j bend with a rubber beveled washer would be best.
i can't tell much about the leak, but it does appear that it comes from the top of the slip nut on the trap arm. also, i'm not sure if the existing trap arm would be compatible with a beveled washer, but it seems to fit snug. i haven't used any goop, paste, mud, caulk, gunk, etc. and am not sure if i should.
any suggestions on what to try or do next? the only thing i'm worried about is that once the plumbing is leakfree, i'll need to disassemble to fit around the pedestal.
thanks for your help!
TheEplumber 04-29-2013 08:46 PM
199 Attachment(s)
I'm thinking you need a flat rubber washer at the j-bend
hinkbot 04-29-2013 09:11 PM
would i need a j bend that supports a flat washer too then?
Javiles 04-29-2013 09:16 PM
plastic and chrome will not seat properly
TheEplumber 04-29-2013 09:18 PM
199 Attachment(s)
yup- either match the old jbend or get new ptrap
jagans 04-29-2013 09:41 PM
Check the P trap for a small rib where they extruded the plastic, and sand it off with Emory Cloth. I personally hate those nylon washers, they simply do not conform like rubber does.
md2lgyk 04-30-2013 07:14 AM
I would use all chrome or all plastic. I prefer chrome for a pedestal sink because the piping is visible. Use some plumber's grease when putting the pieces together and you shouldn't have any leaks.
gregzoll 04-30-2013 07:40 AM
Can you please post pictures. If it sits on a pedestal, you can lift the bowl enough, you can pull the pedestal away, unless someone bolted or glued that to the floor, then placed the sink on top, which I cannot see them doing.
