Pedestal Sink Install Tips Wanted - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-23-2013, 12:21 AM   #1
Pedestal sink install tips wanted
Hi, I am getting ready to install a Kohler pedestal sink and would like any tips anyone may have that would help prevent from cracking the base or sink when I bolt them down. I am setting the base on a tile floor and the sink will be going up against a tile wall as well. Thanks for the help.
Brettgv2 is offline   Reply With Quote
Old 08-23-2013, 12:47 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Here's some tips to start with-
I know it sounds obvious but- read the install instructions thoroughly.
Some models come with a good set- others not so good.
You need to have backing in the wall for a good, smooth installation too.
Although it's not required, a good tight grouping of the rough in pipes helps- you don't have a lot of room- and mount the faucet and drain before you hang the sink.
The sink will pretty much support itself when the wall bracket is installed at the right height- so give it's location special attention. The bracket will have slotted anchor holes to allow you to make a final adjustment.
One tip I learned the hard way- be sure all the anchor holes in the porcelain are free of any casting slag. If not, your screw or lag will grab the slag and break the ear of the basin- not good
Don't over tighten the base or basin to the floor or wall. Just run the screws in until they barely touch.
There's some starters. I'm sure more input will follow...
The Following User Says Thank You to TheEplumber For This Useful Post:
VIPlumber (08-24-2013)
Old 08-23-2013, 09:06 AM   #3
Rewards Points: 13,300
"You need to have backing in the wall for a good, smooth installation too."
To me that's the most important tip.
Everyone I've seen falling off a wall was because there was nothing behind the wall to attach it to. They counted on just the tile and sheetrock to hold it in place, which is just not going to work.
Old 08-23-2013, 10:56 AM   #4
K&B Designer
Live_Oak's Avatar
The install starts way before the install. The wall needs to be opened up, blocking installed, and the visible plumbing made to be in the correct location to be mostly hidden by the pedestal. And change it over to the pretty chrome or ORB or whatever fou fou look you want. But, if you haven't opened up that wall, you're not ready to install anything.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
Cleaning silicone glue residue off of stainless steel sink after install jpfulton248 Remodeling 3 02-23-2013 12:35 PM
Oak stair tread and riser install tips MTWI Carpentry 6 05-04-2012 06:46 PM
A sink in need of a pedestal....help! Gueraloca23 Plumbing 2 01-14-2012 09:10 PM
Pedestal Sink Plumbing Options gth1 Plumbing 5 01-02-2011 04:02 PM
Installing Pedestal Sink on unlevel floor Manuel6 Plumbing 4 08-09-2007 10:31 AM
