Pedestal Sink Gap Between Wall And Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-07-2012, 04:11 PM   #1
Rewards Points: 275
Pedestal sink gap between wall and sink
Just bought a new house and the half bath has a lovely bundle of 2x4s holding up my pedestal sink.
The bottom of the wall has a 4" wall ledge which pushes the pedestal out - problem is the top of the sink has a 4" gap to the wall. See photo:
What are my options here? Do they make something for this sort of thing? Or should I either rip out that wall ledge or extend it up to the window?
Cheers,
Marc
marcus118 is offline   Reply With Quote
Old 12-07-2012, 04:25 PM   #2
Rewards Points: 12,818
There could be plumbing, duct work, wiring, forced hot water pipes, most anything behind that step out.
There's nothing already made to fix that.
But it sure could have been made to look a whole lot better.
One could have been made out of PVC lumber, plywood covered with white formica, finish grade wood painted the same color as the wall ECT.
Could also change the whole thing to a reguler vanity and just cut out the bottom to fit the step out.
Old 12-07-2012, 04:33 PM   #3
Ditto what Joe said.
It's hard to tell from the picture, but I'm guessing there's also a large gap behind the toilet to the wall, correct? If that's the case, and if it was my house, I'd pad out the wall to meet the backs of the fixtures up to the height of the window sill. Use a nice beaded wainscotting. Then I'd install a cap rail/window sill/shelf that ties it all together.
Ishmael is offline   Reply With Quote
The Following User Says Thank You to Ishmael For This Useful Post:
joecaption (12-07-2012)
sink drain exterior wall iskyfly Plumbing 11 02-04-2012 07:38 PM
Pedestal sink installation secutanudu Plumbing 4 07-01-2011 10:57 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
Mounting Corner Wall Mount Sink petedickson82 Plumbing 2 02-17-2010 10:28 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
