Pedestal Sink Drain Replacement? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2012, 11:54 AM   #1
Rewards Points: 552
Pedestal sink drain replacement?
I need to replace the faucet and drain on a pedestal sink in which the plumbing runs down through the pedestal. While I was easily able to remove the faucet with a standard basin wrench, I can't remove the sink drain because there's not enough space to get the basin wrench claws around the large drain nut. I also tried an adjustable wrench and I'm having the same problem. I also tried a TightSpot wrench and it was too large for the nut.
Is there a special pedestal sink tool that'll let me remove the drain nut without having to rip the whole darn sink out of the wall? I'm thinking a basin wrench with smaller pinchers might work, but I've never seen one like that.
Thanks!
kcrossley2 is offline   Reply With Quote
Old 08-24-2012, 12:21 PM   #2
Rewards Points: 1,558
Perhaps some Channel Locks?
I'm guessing bowl has to come off the wall but only a guess.
bob22 is offline   Reply With Quote
Main Drain Replacement? kingbuggy Plumbing 3 05-04-2012 07:58 AM
sink drain exterior wall iskyfly Plumbing 11 02-04-2012 07:38 PM
Condensate draining into sink drain fritzycat1 HVAC 0 01-23-2011 02:39 AM
Drain placement for sink simonb Plumbing 3 09-08-2007 02:08 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
