Pedestal Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-04-2007, 08:53 PM   #1
Pedestal sink
I have a new pedestal basin and stand to install. The manufacturer's guidelines recommend having wood blocking behind the drywall in order to anchor the basin.
I am told that large plastic mollies are strong enough to hold the sink in the drywall. Has anyone done this before?
williamp is offline   Reply With Quote
Old 06-04-2007, 09:42 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You can use mollies but wood backing is better, if you use mollies use metal ones.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 06-05-2007, 09:13 PM   #3
remodeling pro
I personally hate moly bolts with a passion, and would never suggest holding a pedstal sink to the wall with them, or much of anything else for that matter. You will be much better of with toggle bolts, if installing a block is not posssible.
troubleseeker is offline   Reply With Quote
Old 06-14-2007, 04:50 PM   #4
Trouble,
what about using toggle bolts in connection with using silicon on all surfaces on the back of the basin that touch the wall? Would that make it less likely to pull away from the wall if one of the kids starts leaning on it?
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
Installing Pedestal Sink on unlevel floor Manuel6 Plumbing 4 08-09-2007 09:31 AM
Pedestal Sink epolgar Plumbing 5 07-31-2007 03:21 PM
pedestal sink drain leaking sully Plumbing 2 02-05-2007 08:01 AM
Relocating pipes for pedestal sink jerome8283 Plumbing 3 09-18-2006 05:46 PM
