Pedestal Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-26-2012, 08:37 PM   #1
Rewards Points: 164
Pedestal sink
Hey Everyone......question for you all...
So i'm putting in a half bath in the basement, concrete floor, just putting down vinyl flooring, but the floors not perfectly level close to the wall, so the pedestals a bit off kilter.....anyhow...whats the best way to level the pedestal?
ryan50hrl is offline   Reply With Quote
Old 12-26-2012, 08:55 PM   #2
Rewards Points: 6,652
Self leveling cement across the floor, to make the bath even. Let me guess, there is a floor drain nearby, and when this basement was turned into a finished area, no one thought to level the concrete in especially the bath area.
Old 12-26-2012, 09:08 PM   #3
Rewards Points: 164
No, the floor slopes up just a hair at the walls, and thus, causes my unlevel floor problem.
Old 12-26-2012, 09:22 PM   #4
Rewards Points: 14,306
It can also be ground down to make it level.
Old 12-26-2012, 09:26 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 904
I wonder if you could grind the pedestal base to match the slope?
Old 12-26-2012, 09:32 PM   #6
Rewards Points: 558
You can shim the base of the sink and then caulk around itů
epson is offline   Reply With Quote
Old 12-27-2012, 09:44 AM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Use these : http://www.etundra.com/75_Pack_Soft_...Fal_Qgodw2IA3Q
Install them, and then cut them off. Caulking will cover them.
Journeyman Plumber
Pedestal sink gap between wall and sink marcus118 Plumbing 2 12-07-2012 03:33 PM
Pedestal sink drain replacement? kcrossley2 Plumbing 1 08-24-2012 11:21 AM
A sink in need of a pedestal....help! Gueraloca23 Plumbing 2 01-14-2012 08:10 PM
Installing Pedestal sink in bathroom woodworks47 Plumbing 6 08-15-2008 09:56 AM
Pedestal sink - alternative to anchoring to concrete floor? aktheda Plumbing 2 03-19-2008 01:12 PM
