Pedesal Sink Basin Overflow Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2012, 09:09 AM   #1
bryanp22's Avatar
Rewards Points: 300
Pedesal sink basin overflow leak
Hi,
I have a pedestal sink that has a weird leak issue. If water goes into the overflow it seems to leak out on the underside on the left where you put the bolt to attach it to the wall. Is this something where I could fix with some form of epoxy or before I take out my sink am I better off picking up a new sink basin. It definitely seems its leaking from the overflow piping from my testing. I've never seen what the sink basin that is facing the wall looks like so I am unsure if it's a fix or replace kind of thing.
bryanp22 is offline   Reply With Quote
Old 02-06-2012, 11:47 AM   #2
Rewards Points: 1,548
You might want to check if there is a crack in the sink basin back there where it is leaking.
Old 02-06-2012, 10:48 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 996
1 defective sink
2 poor quality
3 B or C grade which take you back to 1
4 Improper P.O. assembly
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
How do I fix this bloody leak? (Laundry sink) Eusibius2 Plumbing 39 02-28-2012 02:22 PM
How to fix, leak under sink, disposal bergerdude Plumbing 3 02-05-2012 10:06 PM
Leak under sink - where to cut? ccannin Plumbing 3 01-18-2009 11:08 AM
How to Detect Leak in Sink iminvalid Plumbing 1 11-05-2008 09:50 PM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
