#1 |
Pea trap leak
I replaced a garbage disposal and had to rebuild the plastic pipes to fit the new disposal. Now the pea trap leaks and I have tried applying the proper torque to stop the leak without success. Any thoughts?
#2 |
Super Moderator
Pea trap leak
Exactly where does the P trap leak--which joint?
New members: Adding your location to your profile helps in many ways.--M-- |
#3 |
Pea trap leak
At joint where pea trap connects from tail coming from the right side of the sink. It is only a slight leak.
#4 |
Pea trap leak
check to make sure you put the white nylon washer in the right way. If it's turned backwards it'll leak for sure. They are slightly tapered on one side.
#5 |
Pea trap leak
I have the tapered facing down!
#6 |
Pea trap leak
The tapered side of the nylon washer is pointing down.
#7 |
Super Moderator
Pea trap leak
thick side to the nut--thin side to the fitting---
If you reused the old nylon washer--they sometimes get stretched out and need replacing--
#8 |
Pea trap leak
if it's a new trap, it may have come with more than one size washer. The washer should slide up the tailpiece very tightly. If it doesn't there could be another smaller size washer that came in the package. If it does, sometimes you really have to tighten the ring pretty snug. Is where it joins on a pretty straight shot? If it's cocked to one side, it causes problems also. I'd also check to make sure the leak is not leaking where the tail joins the bottom of the sink and running down to the p-trap, making it look like the trap is leaking.
sorry, That's all i have, good luck with the fix. i'm out. Last edited by Lightfoot; 06-28-2012 at 07:23 PM. |
#9 |
Super Moderator
Pea trap leak
On rare occasions a small burr on a mating surface can cause a small leak--check the mating surfaces with your finger tip.
#10 |
Pea trap leak
Thanks for you help. I'am out also.
| Display Modes | |
| p trap leak after cleaning | DIYGST | Plumbing | 6 | 12-07-2010 01:17 PM |
| Help fixing a leak and installing a drain trap. | papageek | Plumbing | 0 | 12-01-2010 12:23 PM |
| Lennox G43UF leak under air inducer | spricer | HVAC | 9 | 10-08-2010 07:06 PM |
| Trap Adapter Leak? | kcrossley2 | Plumbing | 6 | 01-27-2010 01:55 AM |
| P Trap leak | industries | Plumbing | 2 | 07-24-2009 04:45 AM |
