PBT Water Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2006, 07:50 PM   #1
Rewards Points: 89
Unhappy
PBT Water Line
Ok....so I live in a townhouse in Maryland, my PBT water line comes in about 3' above the slab through the foundation wall. I have discovered that in my front yard a worrying amount of "squishyness", my guess is a PBT crack/break. I've removed my garden hose with the hope that the water was on...and that it was leaking out the bottom of the hose winder....(wishful thinking).
So the question I have is, with no basement floor to dig up, roughly how much should I expect the replacement to cost me.
mahjohn is offline   Reply With Quote
Old 06-21-2006, 07:57 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You should call local plumbers for free estimates, too many thing to factor in, i.e. trees shrubs, type of ground, depth of line, see what I'm saying?
Ron The Plumber is offline   Reply With Quote
Old 06-21-2006, 08:01 PM   #3
Rewards Points: 89
other than a squishy patch...any other signs to look for ?
Old 06-21-2006, 10:17 PM   #4
Journeyman Plumber
Check water meter see if it is always turning.
Old 06-22-2006, 03:53 PM   #5
Sciencerules
MAS2006's Avatar
Find the main service shut off for home and turn off, if meter still turning leak between shut off and meter.
MAS2006 is offline   Reply With Quote
Water line for new refrigerator? pa555 Plumbing 5 06-08-2012 07:06 PM
Ticking Hot Water Line HWPipes Plumbing 3 11-25-2008 01:54 PM
Adding a new water line to dishwasher and fridge? PMichaud Plumbing 18 01-05-2007 08:00 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
