Old 10-30-2010, 02:38 PM   #1
Patio drain
Have on my patio a drain (the pipe is about 2"), during a shower the leaves are cloging somewhere inside. What to use better to clean...A snake doesn't work well, thanks.
silvermike is offline   Reply With Quote
Old 10-30-2010, 03:30 PM   #2
Patio drain
Where does the drain lead to?
Ishmael is offline   Reply With Quote
Old 10-30-2010, 04:06 PM   #3
Patio drain
you need a jetter. i'd call a few plumbing shops to get quotes, or if you're brave call a rental yard and find out if one's available to rent
the_man is offline   Reply With Quote
The Following User Says Thank You to the_man For This Useful Post:
silvermike (10-30-2010)
Old 10-30-2010, 05:40 PM   #4
Patio drain
it is connected to the street storm
Old 10-30-2010, 05:57 PM   #5
Patio drain
These work pretty well:
http://www.google.com/products/catal...ed=0CFAQ8wIwAQ#
The Following User Says Thank You to Ishmael For This Useful Post:
Tags
leaves clogging
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
