Patio Cooling Misting System - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2010, 04:36 PM   #1
jburd964's Avatar
Rewards Points: 166
Looking of someone with input that has had some dealings with patio misters. I've seen them in amusement parks that work really well, haven't had any experience with them for home use.As seen on this web site http://www.rapidcool.net/applications_home.html
This site looks over the top to me.
jburd964 is offline   Reply With Quote
Old 07-25-2010, 04:45 PM   #2
They work...I also have a misting fan
Old 07-25-2010, 08:17 PM   #3
jburd964's Avatar
Rewards Points: 166
What type do u have? What it cost? Pump type? How many feet do you have?
Old 07-25-2010, 08:29 PM   #4
I do not have a pump
It works off the house - 80 psi here
Its about 36' of misting - Misty Mate
I bought it at the end of last year for about $30
I need to replace the part where the mister attaches to the hose
Other then that it works great
Old 07-25-2010, 08:38 PM   #5
jburd964's Avatar
Rewards Points: 166
How do u get 80lbs of pressure without pump? Does it drip?
Old 07-25-2010, 08:42 PM   #6
House pressure is 80 psi here
Its mounted against a screen house
So if the wind blows it back against the screen house I can get drips
Old 07-25-2010, 08:46 PM   #7
Electrician
Proby's Avatar
Doesn't that raise the humidity in the backyard and make it more uncomfortable?
Proby is offline   Reply With Quote
Old 07-25-2010, 09:07 PM   #8
So far in use it cools the area down
The mist is at ground temp - cool water from the hose
We also use a misting fan
Between the 2 they can really cool the area off
They are both by our pool area
Burnham Series 2 Cast Iron Radiator System SybrDave HVAC 2 12-10-2009 05:24 AM
New cememt patio stained by wet leaves Bhoward Landscaping & Lawn Care 7 12-03-2008 11:35 AM
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 07:31 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 10:56 AM
