Patching A Cast Iron Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2009, 07:01 AM   #1
Unhappy
patching a cast iron pipe
i just replaced a 4 inch pipe in the basement that connects to the sewer line. when we went to the basement to look around, we saw a small leak in the line that goes out to the street. it is really old and probably needs replacing but i am afraid to cut into a piece of it for fear of cracking the rest of the pipe and causing an incredibly expensive repair i can't afford just now. Is is possible to do a patch? the crack appears to be really minute. any suggestions?
realbeginner920 is offline   Reply With Quote
Old 08-25-2009, 07:21 AM   #2
Rewards Points: 6,652
You have to use what is called a "Band Patch". This is only a temporary solution, until you can have a plumber replace with a new section.
Old 08-25-2009, 07:31 AM   #3
thanks a bunch. i will look for it.
Old 08-25-2009, 08:12 PM   #4
Now if you are creative, do the Navy way, and use a Rubber patch, Hemp rope, and Tar to make a temp/long term patch. Personally, the band patch is cleaner, but you have to love the Hull tech way.
Old 08-26-2009, 06:05 PM   #5
Wow
You just took me back to my old Tin Can days in the Boileroom.
Steamin Demon
Boiler tender Vietnam Vet.
SULTINI is offline   Reply With Quote
Cast iron pipe broken? tervic Plumbing 6 02-18-2009 06:23 PM
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-17-2009 11:18 PM
Loosening bolt on cast iron pipe kegger42 Plumbing 2 09-23-2008 11:12 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 05:39 PM
