Patch Pvc - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-21-2013, 08:03 AM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Patch pvc
I have one of my gutter downspouts going into a PVC pipe, which is into a concrete slab.
That pvc pipe has a split in it. And rain comes out that split.
What can I patch that PVC pipe with
Barry
Barry J is offline   Reply With Quote
Old 07-21-2013, 08:09 AM   #2
DIY staff
Rewards Points: 7,174
See if you can find a repair coupling---those do not have a center stop and can be slipped over the pipe stub that is sticking out of the slab----
you may not find one in a retail store---a trip to a plumbing supply house might be needed---Mike-----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (07-21-2013), TheEplumber (07-21-2013)
Old 07-21-2013, 08:14 AM   #3
Rewards Points: 14,276
Can you get to it to just replace it. PVC is inexpensive and easy to splice.
Old 07-21-2013, 08:38 AM   #4
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
I would replace it , but the crack in the pipe is too close to the concrete
Old 07-21-2013, 08:49 AM   #5
DIY staff
Try the repair coupling----------cheap--solid--and simple----
Old 07-21-2013, 09:15 AM   #6
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
I have limited space around the pipe
Old 07-21-2013, 05:41 PM   #7
DIY staff
Post a picture---You might have a jack hammer in your future----
Old 07-27-2013, 11:35 AM   #8
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Actually a hack saw will be in my future. The 4in PVC will be cut level with the existing concrete, then Tuesday the stamped concrete will be poured over it, to bury it. I will put a couple of curved pieces to go into my wife's flower garden which is about 3 ft around the corner....problem solved
Old 07-27-2013, 11:37 AM   #9
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Reason why I'm doubg this, is because I tried to clean out the pvc, with plumbing tools and a shop vac, I can get as far as the elbow beneath the concrete and in about a foot, but then it's packed full of crap
The Following User Says Thank You to Barry J For This Useful Post:
oh'mike (07-27-2013)
Slightly recessed drywall patch ARB Drywall & Plaster 7 03-19-2013 08:00 AM
Roof patch job ok or not? daluu Roofing/Siding 8 11-07-2012 08:56 AM
EPDM Roof Patch antelope420 Roofing/Siding 1 05-11-2010 08:20 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Floor patch HomeDepot23 Flooring 2 07-24-2008 06:03 AM
