Paste Vs. Water-soluble Flux - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-04-2008, 09:36 PM   #1
Rewards Points: 1,062
Question
paste vs. water-soluble flux
what is the difference b/ween the two and does it matter which type i use for regular water-supply pipe soldering ?
i have so far used paste but have recently bought a can of water-soluble because that was the only kind available in the store i was at.
Old 06-05-2008, 08:21 AM   #2
47_47's Avatar
Rewards Points: 50
Good question, I use paste also. My guess paste flux will continue to etch the copper, unless wiped while water soluble will not. It will probably be an EPA or HAZMAT thing or cost factor. I'll hang out for the pros answer.
47_47 is offline   Reply With Quote
Old 06-05-2008, 08:54 AM   #3
Journeyman Plumber
Ron The Plumber's Avatar
It don't matter the type you use, it serves a purpose and thats to join copper pipe and fitting together. Water soluble just means it rinses out faster after the water is run though the pipes.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 06-05-2008, 09:22 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I've used several. Normally we use LACO which they say on the tub is a paste, even though it doesn't REALLY look like a paste. It is also water soluble.
Everflux is a pasty looking flux, and it also says that its a water soluble paste.
Journeyman Plumber
Old 08-02-2009, 08:06 PM   #5
Prefer non-water soluble
I just had an experience. All one store had was water soluble flux. Two hours and much frustration later things just weren't working. I have sweat fit joints before but NEVER had this experience. The solder would not pull into the joint.
I then went to another store and talked to a plumber who happened to be shopping for supplies. He said he hates the water soluble due to the same experience: just does not pull in the solder like non-water soluble (oil based?)
Bought the non-water soluble flux paste, and things went MUCH smoother.
I am just a DIY person, so I am not a pro, but that was my experience. Would love to hear what more pro's have to say about it.
tony.klepic is offline   Reply With Quote
Old 08-03-2009, 09:57 PM   #6
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
I hate that water soluble crap and wont even let a tub get within 10' of my truck. It would be a bad influence on my Oatey #5 and Oatey #95
JDC is offline   Reply With Quote
Old 08-05-2009, 12:11 AM   #7
Master Plumber Lon
Send a message via Yahoo to lonsplumbing
Flux And Flux H20
oatey rules on flux unless you get a know it all inspector.
lonsplumbing is offline   Reply With Quote
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
