Which Part To Replace? On My Hot Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2007, 05:06 PM   #1
Which Part to Replace? on my Hot Water Heater?
Help? My hot water heater is on the fritz! I get no hot water; I go and hit the reset button and get hot water for about 1.5 showers, then back to no hot water? Every time I reset it, it works, but does the same thing? It is not the fuse in the house? Not sure if this would be the thermostat? If so top or bottom? Or what? Can anyone help me with this PLEASE!!! thank you. -sam
ssammiewh is offline   Reply With Quote
Old 05-26-2007, 05:40 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Replace the top and bottom stats.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 05-26-2007, 05:52 PM   #3
RON THE PLUMBER... - Top and Bottom Stats...
Ron -Thank you so much! That is what I thought it was. I am fairly handy and can fix most things, I have some books and replacing the thermostats looked simple enough, is there anything specific I should remember/ do/ be careful of/ anything... that you could offer?
Also, I am/was pretty sure that the bottom one was the (bad one) so can I just replace that one or is it better to replace them both?
The heater is in a crawlspace and with all the rain we have had here, there was a bit of standing water overnight (sump pump gave out and had to be replaced) ..... just to make sure, the problems I have wouldn't be related to anything with the drain valve right?
Thank you so much for all the help! I would love to take warm showers again! -sam
Old 05-26-2007, 05:56 PM   #4
Journeyman Plumber
Yes replace them both, upper and lower, just make sure you get the wires back on the same terminals you take them off at, and before working on it, shut power off.
Old 05-26-2007, 06:03 PM   #5
RON ... thanks
Yes Ill remember to shut off the power! ha ha I was going to add that but figured I would look dumb ha ha
thank you so much for all your help! I really appreciate it! Now I just have to get the guts to go work in that icky crawlspace with the snakes that seriously freak me out!! In the dark!! AHHHH well see how close to winter it gets before I can get the guts to do it ha ha!! thanks again! - sam
Old 05-28-2007, 08:32 AM   #6
Long-Time DIYer
Mike Swearingen's Avatar
Sam,
Take a look at the tstats layout and number of screws before you go to the store, and get new tstats just like them (does not have to be same brand). Exchange the wires one at a time from the old to the new. Can't go wrong. Easy.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-15-2007, 11:37 AM   #7
I hope you are not a claustrophibic snakeophobe. Okay I know the term snakeophobe doesn't exist. Good luck. I have worked in tight little crawl spaces. Didn't like it much, but at least I didn't have snakes.
Gerry
Gerry Kiernan is offline   Reply With Quote
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
