Old 02-01-2013, 01:13 PM   #1
paranoid question
i have a dual-water heater gas tank. if one of the tanks' "fire" dies, i wouldnt notice it coz the other tank will still supply hot water in my house.
i guess i'm just being paranoid, what are the chances it will cause fire or carbon monoxide poisoning?
i'm comparing it to gas oven left "on" but without fire. gas will escape and may fill up the room which is dangerous.
dumbengineer is offline   Reply With Quote
Old 02-01-2013, 01:58 PM   #2
Super Moderator
paranoid question
There are safety devices built in that SHOULD keep it from blowing up---if is not working tourn it to "OFF' and shut off the gas to it----
Old 02-01-2013, 02:46 PM   #3
Roofmaster
paranoid question
What is a dual water heater gas tank???????
" A lot of men build things, and a lot of things fall down "
Old 02-01-2013, 03:08 PM   #4
747
registered
747's Avatar
paranoid question
I"m assuming one which supplies hotwater for heat and hotwater for domestic use.
747 is offline   Reply With Quote
Old 02-01-2013, 03:49 PM   #5
joed's Avatar
paranoid question
If the gas was flowing you would smell it. You can also get combo detector that will detect CO, propane and natural gas.
http://www.kiddecanada.com/utcfs/Tem...%3D463,00.html
Do not PM with questions that can be asked in a forum. I will not respond.
Old 02-01-2013, 05:25 PM   #6
r0ckstarr's Avatar
paranoid question
Shouldn't it have individual thermocouplers to prevent that from happening? I had a similar fear until I found out what a thermocoupler was and what it did.
r0ckstarr is offline   Reply With Quote
The Following User Says Thank You to r0ckstarr For This Useful Post:
dumbengineer (02-02-2013)
Old 02-02-2013, 01:40 PM   #7
paranoid question
tnx
Thermocouple
  • The thermocouple is a safety device that shuts off gas when the pilot light goes out. It's generally part of the electrical field that generates an electric current by producing heat. Thermocouples are predominantly made of two U-shaped conductors of similar metals which create a circuit to control valves and relays. In most devices, such as water heaters, furnaces and gas fireplaces, thermocouples are located near the pilot light. The thermocouple controls the main gas valve that permits gas to flow to the pilot light. Once the pilot light extinguishes, the safety device shuts off gas flow. The thermocouple does not open the gas valve unless the pilot light is lit to prevent gas from needlessly flowing to the device and haphazardly escaping into the air.
The Following User Says Thank You to dumbengineer For This Useful Post:
r0ckstarr (02-06-2013)
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
