Pan Under Water Heater Is Corroding? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-02-2012, 06:46 PM   #16
Rewards Points: 6,652
Originally Posted by Homerepairguy View Post
I just had a thought. Is there a capacitor in the electronics above the corroded part? If yes, it's probably leaking and the acid corroded the pan.
HRG
Um, Capacitors do not have acid in them. They contain oil.
Old 06-02-2012, 06:49 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 818
Why do you even have a pan? Its on a concrete floor so not required in my area. Does it even have a drain?
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (06-02-2012)
Old 06-02-2012, 08:05 PM   #18
a pan is required. our floor doesn't have a drain, but the tank does. does that answer your question?
neight is offline   Reply With Quote
Old 06-02-2012, 08:42 PM   #19
Plumber
Rewards Points: 818
Obviously the tank has a drain. I meant does the pan have a drain, not the floor. I didn't see one in the picture.
Old 06-02-2012, 09:00 PM   #20
[quote=TheEplumber;934835]Obviously the tank has a drain. I meant does the pan have a drain, not the floor. I didn't see one in the picture.[/quote
yes. it's actually located 1/4 the way away from the corrosion hole. you can see it in pic #3 of my post
Old 06-02-2012, 09:24 PM   #21
Plumber
Rewards Points: 818
[QUOTE=neight;934857]
Yep, I see a hole to receive the drain pan pipe but no pipe. If the pan fills with water to that hole it will spill onto the floor rendering your pan virtually useless. It is not protecting your floor as it is intended.
Here's my recommendations: Replace pan with a plastic one and pipe the drain to a floor drain or exterior.
Patch the existing holes per HRG's method and pipe the drain out.
Or (my choice) get rid of the pan.
As to whats causing the corrosion, I think it's the concrete
Old 06-02-2012, 09:35 PM   #22
[quote=TheEplumber;934900]
replacing the pan isn't an issue. it's what is causing the corrosion? why is concrete corroding the pan?
Old 06-02-2012, 09:53 PM   #23
Plumber
Rewards Points: 818
[QUOTE=neight;934917]
Good question- to me it sounded better then drippy electronic acids
TBH, I don't have an answer to your corrosion culprit. Perhaps it was soldering flux left over when the heater was installed...
Old 06-02-2012, 10:00 PM   #24
[quote=TheEplumber;934936]
I know the difference between solder, flux, and corrosion. if i didn't, i'd be a bad home inspector. this is something i haven't seen before, and it's happening in my home.
Old 06-02-2012, 10:05 PM   #25
Plumber
Rewards Points: 818
OK, my last guess then I'm watching the OT of the Stanley Cup-
Corrosive condensation from the bottom of the burner
Old 06-02-2012, 10:23 PM   #26
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
what kind of pipe is coming off your t and p, is that going thru your pan. looks a little suspect the pic to me any way has like green corrosion.
wctekkk is offline   Reply With Quote
Old 06-02-2012, 10:24 PM   #27
DIY staff
Rewards Points: 7,174
This is that damnedest thread--the pan serves no useful purpose--it's old and rotten--so replace it with one that doesn't leak and be done with it--
what difference does it make why a thin galvanized pan corroded?
gregzoll (06-03-2012)
Old 06-02-2012, 10:40 PM   #28
Plumber
Rewards Points: 818
Old 06-02-2012, 11:56 PM   #29
Homerepairguy's Avatar
Rewards Points: 998
Did you notice that I mentioned "electrolytic" capacitor? Electrolytic capacitors do contain acid.
Here's a quote from wikipedia regarding electrolytic capacitors:
***** The electrolyte is usually boric acid or sodium borate in aqueous solution, together with various sugars or ethylene glycol which are added to retard evaporation. *****
Article at: http://en.wikipedia.org/wiki/Electrolytic_capacitor
Here's another website that lists 5 different types of acid used in electrolytic capacitors. Look at the chart at the bottom of the page:
http://www.elna-america.com/tech_al_principles.php
I assume what you are thinking of are oil impregnated paper capacitors that are used in older equipment and a/c oil impregnated capacitors.
HRG
Homerepairguy is offline   Reply With Quote
Old 06-03-2012, 01:15 AM   #30
sacramento plumber
wctekkk's Avatar
Rewards Points: 77
were is a Capacitor on that w/h
Tags
corrosion , hot water heater
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
