Painted Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2013, 04:32 PM   #1
Rewards Points: 878
Painted Copper Pipe
Ok this idiot channeled out concrete and relocated the baseboard copper pipe in it. Well was told copper can't touch the concrete and should replace it with Pex. Well I was also told to wrap the bottom half with insulation( could not wrap the entire pipe because the top would have been above the floor) and use a high heat spray paint to coat the top part. As you can see this is what I did. Will that paint react with the copper? Thanks.
Mstrlucky74 is offline   Reply With Quote
Old 11-03-2013, 04:54 PM   #2
joed's Avatar
Rewards Points: 13,354
The paint will be fine. The problem area however is the bottom of the pipe where it contacts the concrete. The problem is the acids in the concrete will eat at the copper and create a leak. It take 5 years. It take 35 years.
Old 11-03-2013, 06:43 PM   #3
Rewards Points: 878
The middle to bottom half is wrapped in insulation. I cut the insulation in half and wrapped it . It was the top half that was not covered so I was told I can use the high heat engine spray paint to protect the cooper. We are putting tiles over but have to put thinset down over the copper pipe or do you recommend something else? Thanks
Old 11-04-2013, 04:14 AM   #4
DIY staff
Rewards Points: 7,174
Lay some plastic over the painted pipe and get the tile work done--
While not ideal, I've seen this type of instal last a long,long time----by the time a failure occurs you will be to old to care----
Old 11-05-2013, 04:39 AM   #5
Rewards Points: 878
What is the nest stuff to lay over the plastic/pipe for the tile to adhere to. Thanks
Old 11-05-2013, 05:29 AM   #6
DIY staff
Just cut a strip of plastic sheet and tuck it around the pipe----pack the void with some modified thinset---let that set up--and then set your tile----
crayola110 (11-06-2013)
Old 11-05-2013, 05:56 AM   #7
Rewards Points: 878
The Following User Says Thank You to Mstrlucky74 For This Useful Post:
oh'mike (11-05-2013)
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
soldering painted copper pipe? darsunt Plumbing 2 03-29-2011 05:20 AM
Copper Pipe Water Lines trophywalleye Plumbing 3 03-04-2011 08:44 PM
PVC air admittance value and copper waste pipe diy888 Plumbing 2 02-16-2011 07:48 AM
Copper to Black Pipe Gas Connection dwolek HVAC 1 03-15-2010 05:02 PM
