Pad For Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2011, 10:50 AM   #1
Pad for Water Heater
We have two water heaters in our home. One recently needs to be replaced. We were told that it would have to be put on a concrete slab (it is presently in a "crawl" space). The craw space is large and you can easily stand up in it.
My question is whether the pad needs to be poured concrete or if thee is another solution (cinder blocks?). The pad would sit on dirt.
Thanks so much.
BioLaw is offline   Reply With Quote
Old 02-01-2011, 10:58 AM   #2
Owner
LateralConcepts's Avatar
Thanks so much.
Cinder blocks, 2x4's, whatever. Just can't sit on the dirt floor.
I'm not sure what they're called, but they make those high density styrofoam pads like you'd see under an AC unit outdoors. They have kind of a concrete or stucko finish. Maybe check with an HVAC wholesaler in your area.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 08:31 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
