Packing Material For Plastic Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-25-2013, 03:29 PM   #1
Packing material for plastic valve
Hi,
I am wondering if I can use graphite packing string on a plastic hot water cutoff valve (the original packing (seemingly a plastic washer) has disintegrated).
If not, would you have other suggestions? (the valve will be a big job to replace and I don't have the time at the moment).
Thanks,
JD
cscjjd is offline   Reply With Quote
Old 04-25-2013, 04:33 PM   #2
MarginallyQualified
Rewards Points: 2,464
Find the time.
The Following 2 Users Say Thank You to TarheelTerp For This Useful Post:
gregzoll (04-26-2013), jagans (04-26-2013)
Old 04-26-2013, 08:49 AM   #3
Rewards Points: 3,130
Plastic valves are not designed to be repaired/repacked (not residential ones anyway). They are also not very reliable. Replace the thing with a metal, full-port ball valve.
The Following 2 Users Say Thank You to md2lgyk For This Useful Post:
Old 04-26-2013, 09:26 AM   #4
Rewards Points: 582
save yourself the trouble.....replace the valve...ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
Old 04-26-2013, 10:41 AM   #5
Roofmaster
Rewards Points: 2,172
Its faster to replace the valve than it is to screw around with the packing which will not work anyway, so whats the point? If you are that busy, hire a professional plumber and have them do it.
The Following User Says Thank You to jagans For This Useful Post:
ben's plumbing (04-26-2013)
Shut off valve for outdoor spigot C4per Plumbing 15 11-24-2012 08:50 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
TPR valve leaking - closed system? Hidden check valve? Pressure mystery dustout Plumbing 0 09-23-2012 06:36 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 04:04 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
