P-Trap Problem Or Not? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2013, 10:32 AM   #1
P-Trap problem or not?
Been having smell problem with my shower. Often get the "cat" urine smell.
Tried cleaning the pipes to ride smell using old fashioned method (eg vinegar and bake soda) . . this didnt work so thought may be a P-Trap (or lack of Ptrap).
However when I opened drain there looks to be standing water in the drain.
So maybe not? Yes? No?
Any thoughts on how to target the problem?
styopa is offline   Reply With Quote
Old 02-03-2013, 10:39 AM   #2
Rewards Points: 14,306
Dump some water down the drain and see if the smell stops.
If not then most likly you have a leaking drain under the tub.
Any access under it to see it?
Old 02-03-2013, 10:50 AM   #3
do you have cats? is the smell only in the shower? could it be water under the tile and really bad mold? pictures would help a lot.
Old 02-03-2013, 11:23 AM   #4
Hello
When the water has run (eg after shower) The smell goes away for a little while. Same when you do a vinegar/soda flush with boiling water.
This plus fact that construction is brand new makes me I think it's not a mold problem
BTW no cats and no access under shower
Old 02-03-2013, 11:46 AM   #5
Rewards Points: 3,818
New construction usually has a year's warrenty with it,call the builder and have him take care of it.
Canarywood1 is offline   Reply With Quote
Old 02-03-2013, 11:50 AM   #6
tks but No warranty - I have to deal with this myself.
Old 02-03-2013, 11:55 AM   #7
DIY staff
Rewards Points: 7,174
Even new work sometimes has problems-----so call the builder ,as suggested--or get someone else in,like a plumber to see what an experienced person would say-
Sewer gas is methane and has a distinct odor----what you are describing is not sewer gas--
Get a tub of plumbers putty and completely cover or otherwise block that drain----if the smell vanishes--then the smell is ,most likely, coming from the drain.
Javiles (02-03-2013)
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 06:16 AM
Connecting brass trap to cast iron (Noob) acr2001 Plumbing 7 08-22-2012 12:37 AM
Would this be a 'P' trap or an illegal 'S' trap? klondiker Plumbing 7 04-06-2012 10:18 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
