P Trap Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2011, 11:04 PM   #1
p trap problem
installing new shower. need advice concerning the p trap. Can the shower drain be within 2 inches above outlet pipe for p trap? The outlet pipe into the main drain for the bathroom ( shower, toilet, and sink) is on same level (floor) as bathroom..its in closet of adjoining bedroom..with proper vent thru ceiling. gotta build new subfloor for shower base..so question is if i get the 1/4 inch per foot called for my code, how close can i put the shower drain on the p trap? can I attach it directly to the p trap? the shower drains into the main line directly no other tie ins. Im gonna position the shower drain 12 inches from the wall. Any ideas?
chulett is offline   Reply With Quote
Old 02-05-2011, 04:19 AM   #2
Rewards Points: 212
bluebird5 is offline   Reply With Quote
Old 02-05-2011, 10:06 AM   #3
there isn't any minimum length of the tailpiece between the shower strainer and the p trap. as long as it fits and you have minimum grade on the drain line you're good to go
the_man is offline   Reply With Quote
Old 02-05-2011, 01:57 PM   #4
Rewards Points: 212
thats right cut it short enough to fit in the joists and make sure your drain line drops 1/4 per foot without running through the bottom of the ceiling and don't forget your vent it goes after the trap so that there is no suction behind the trap that will dry it out. put a tee and turn in vertical and go as high as you can and then attach the vent unless you are just right at the main stack. you just want to make sure that your vent doesn't fill with water
Old 02-05-2011, 02:05 PM   #5
Rewards Points: 212
http://www.familyhandyman.com/DIY-Pr...e/Step-By-Step
click step by step and you will find a good drain image
Old 02-05-2011, 05:51 PM   #6
Rewards Points: 150
Most codes call for a max on the length, but nothing on the minimum
braindead is offline   Reply With Quote
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
septic problem??? jjrbus Plumbing 2 09-09-2009 09:59 PM
Weed problem, bug problem, or both? hayzen Landscaping & Lawn Care 1 08-25-2009 06:33 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
