P Trap Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2010, 08:31 AM   #1
p trap problem
after installing my new vanity i noticed the drain pipe in the wall is only an inch of so above the shelf and does not leave enough room for p trap. do i have any options?
kferguson76 is offline   Reply With Quote
Old 05-23-2010, 08:56 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Cut a notch in the shelf.
Coastal South Carolina
Old 05-23-2010, 09:06 AM   #3
p trap problem
i was thinking that but vanity was pretty expensive and below the shelf is a storage drawer. i was think of using a 90 degrees out of wall drain and up to desired height but not sure if that will work? what do you think?
Old 05-23-2010, 09:55 AM   #4
A "Handy Husband"
rjniles's Avatar
You will eat up the space you need to install the trap and it will be clog point. Also does not meet code.
Open the wall and move the tee for the trap arm up.
Old 05-23-2010, 10:20 AM   #5
Licensed Master Plumber
Either lower the inlet or raise the vanity
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
septic problem??? jjrbus Plumbing 2 09-09-2009 09:59 PM
Weed problem, bug problem, or both? hayzen Landscaping & Lawn Care 1 08-25-2009 06:33 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
