Old 07-30-2007, 11:21 AM   #1
p-trap primer
Hi
I am in the process of completing basement reno. I got a plumber in to do the rough-in plumbing and I am completing the installation of the fixtures. The plumber has run plastic tubing to all the floor drain traps to ensure that there is always water in the trap. This tubing has beeen routed to where I will connect the laundry tub and washing machine. My question is: how to I connect the plastic tubing into the drain line so that water from the washing machine will keep the traps full of water?
thanks
lpcon is offline   Reply With Quote
Old 07-30-2007, 08:44 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
p-trap primer
Most primers connect to the side via a fitting called a BAP adaptor, are they not connected to the traps at all?
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 07-31-2007, 11:51 AM   #3
p-trap primer
The plastic tubing has been connected to the the floor drain traps, I now need to connect the supply end
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 08:30 PM
old primer firsthomegal Painting 2 06-21-2007 09:28 PM
Primer for MDF? NateHanson Painting 13 05-09-2007 10:09 PM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 07:38 AM
Please tell me this primer is going to dry!! Autumnknight Painting 6 09-20-2006 08:22 PM
