-   -   p-trap primer (http://www.diychatroom.com/f7/p-trap-primer-10268/)
lpcon 07-30-2007 10:21 AM
p-trap primer
Hi
I am in the process of completing basement reno. I got a plumber in to do the rough-in plumbing and I am completing the installation of the fixtures. The plumber has run plastic tubing to all the floor drain traps to ensure that there is always water in the trap. This tubing has beeen routed to where I will connect the laundry tub and washing machine. My question is: how to I connect the plastic tubing into the drain line so that water from the washing machine will keep the traps full of water?
thanks
Ron The Plumber 07-30-2007 07:44 PM
Most primers connect to the side via a fitting called a BAP adaptor, are they not connected to the traps at all?
lpcon 07-31-2007 10:51 AM
The plastic tubing has been connected to the the floor drain traps, I now need to connect the supply end
