Old 07-18-2011, 09:01 AM   #1
P Trap Leaking
I recently posted a thread about my drain pipe under my kitchen sink, which you can find here.
Drain Pipe
After I hooked everything up and made sure everything was tight, I turned the water on to see for any leaks. Everything drains, but I have a small leak under the compression nut that tightens the p trap to the 90 deg elbow that goes into the pipe in the wall. Basically, it drains some water that is left in the trap. Not a big leak, but a leak none the less. My question is, am I missing anything on the hookup? The only thing I can think of is there is a plastic piece that goes of the lip on the 90 deg elbow where it goes into the p trap. Other than that, I am out of ideas. Help?
ws450r is offline   Reply With Quote
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 12:46 PM
Please help with p trap (pics) techprincesse Plumbing 12 06-03-2011 04:17 PM
Leaking Trap Connection bklusa1 Plumbing 3 02-17-2011 10:50 AM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 11:10 AM
Leaking Condenation Trap - Bryant falcon HVAC 9 04-01-2009 07:17 PM
