Old 07-22-2009, 12:56 PM   #1
P Trap leak
I had to replace the pop up drain in my bathroom sink. I'm reattaching the p trap, and the back part that connects into the pipe coming out of the wall leaks. I am using the same pipes, and they did not leak before. What am I doing wrong?
I did take the p trap off to put the pop up drain in place. Is it possible I lost a washer somewhere?
Thanks.
industries is offline   Reply With Quote
Old 07-22-2009, 01:24 PM   #2
P Trap leak
It is likely that you dropped a nylon seal out of the trap. Should be 1-1/4". Look around the floor for it. Most are light in color (like silicone colored) and can easily be missed.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 07-24-2009, 04:45 AM   #3
P Trap leak
I've just recently got into having to do some plumbing here and there to my own problems and helping some other people out so take what I have to say lightly. When you say coming out of the wall I am assuming you talking about incoming water and not a drain. If you are talking about the screw on lines then just like already stated you probably lost a gasket somewhere.. Happened to me. If you are talking about actual incoming pvc water supply then be sure you have used primer following a generous supply of pvc glue on top of the primer before reconnecting.
Just Some Guy is offline   Reply With Quote
Cat trap fever radtek General Discussion 13 05-31-2009 07:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 11:10 AM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 07:30 AM
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 09:18 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 02:18 PM
