P Trap & Galvanized Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2008, 11:36 PM   #1
DIY'r
Send a message via Yahoo to Catchinyellows
Question
Hey all... I am remodeling my bathroom and moved my sink a bit and the P Trap no longer matches up quite right which is causing it to leak. I would like to switch to PVC, but I don't know how or what I need to do or use to connect the PVC to the galvanized pipe. I have a 1 1/2 galvanized pipe with thread sticking out.
Any help would be great.
Catchinyellows is offline   Reply With Quote
Old 11-10-2008, 05:09 AM   #2
Whatamess
Go to L/HD and get a threaded 1 1/2" pipe to 1 1/2" slip joint PVC.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 11-10-2008, 06:16 PM   #3
biggles's Avatar
that 1 1/2" galv. sticking out of the wall....prep it by wire brushing the threads and wrap it with teflon clockwise looking into it .take that coupling 1 1/2" PVC slip by FM thread and hand thread it on tight and with a channel lock pliers give it ONE full turn tight and you ready to PVC pipe away.pre-fit all the trapping pipe before you do any glueing.
Old 11-10-2008, 10:29 PM   #4
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
You can use an 1-1/2" trap adapter nut available at any mom and pop hardware store, big box stores and plumbing supply houses.
JDC is offline   Reply With Quote
Old 11-11-2008, 10:22 AM   #5
The pipe is probably threaded on the end in the wall also. I would remove the piece of pipe and use a PVC MIP (male iron pipe) to glued adapter. You can cut whatever length of PVC pipeyou need and glue it into the adapter and then screw it into the fitting in the wall. I do not like PVC FIP (female iron pipe) fittings since they can be easily overtightened and crack.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Tags
galvanized , leak , p trap
Water Galvanized pipe to Pex sssalas Plumbing 6 09-24-2008 02:47 PM
burying galvanized steel pipe amakarevic Plumbing 9 08-19-2008 10:37 AM
Replacing shower valve - galvanized pipe? rjniles Plumbing 2 05-08-2008 09:29 PM
repairing old galvanized pipe? darsunt Plumbing 2 04-08-2008 12:39 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
