P-trap On In Exterior Wall Install To Prevent Freezing - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2013, 01:24 PM   #1
Rewards Points: 28
p-trap on in exterior wall install to prevent freezing
I am installing a laundry on the 2nd floor of my home. I have the easiest access to run the drain to the basement next to an existing vent for the bathroom below on the 1st floor.
I would like to install the p-trap in the wall for a clean look and gain a few more inches in the small space.
I live in Southeastern Michigan so it can get cold, but the walls have fiberglass insulation. Can I wrap the p-trap in more insulation or spray foam it? When I removed the drywall, yesterday, to expose the drainpipe it didnít seem cold because of the insulation.
I want to prevent freezing, there shouldn't be cold air running over the trap in the insulated wall.
Any help would be appreciated.
Smahoney6 is offline   Reply With Quote
Old 02-27-2013, 10:01 PM   #2
Rewards Points: 243
You can insulate between the trap and the exterior, but don't insulate between the trap and the interior of the house. That way the trap will pick up the warmth of the house.
chemman is offline   Reply With Quote
The Following User Says Thank You to chemman For This Useful Post:
Smahoney6 (03-01-2013)
Old 03-01-2013, 08:42 AM   #3
Rewards Points: 28
To ensure no freezing can I put the trap in the basement before the line goes to the main waste line? Effectively have like a 15ft standpipe?
So like the orange pipe in the picture.
Old 03-01-2013, 09:07 AM   #4
To meet IRC and UPC codes the trap must be as close as possible to the fixture. I think being that far of drop to the trap the velocity of the water may siphon it.
OpieGoneBad is offline   Reply With Quote
The Following User Says Thank You to OpieGoneBad For This Useful Post:
Smahoney6 (03-26-2013)
Tags
drain conduit , exterior wall , freezing , p-trap
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 02:18 PM
Help fixing a leak and installing a drain trap. papageek Plumbing 0 12-01-2010 11:23 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 03:35 PM
How do I install a pressure relief valve in a freezing area terryplys Plumbing 2 04-10-2009 07:31 AM
