#1 |
Overloaded Vertical Drain
Currently I have two sinks from two adjoining bathrooms connecting to a 1 1/2" vertical drain. I would like to replace the vanity in one of the bathrooms with one having a double sink. This would mean three fixtures would be connected. The double sink would be plumbed so each one would have its own p-trap and connect to a double fixture cross.
I called a local plumbing company and they said they would plumb the new fixtures but that it wouldn't be to code. They said it would be fine having three fixtures just not to code?? What would be the consequences of having three fixtures tied together. Is it just to protect the possible situation where are three fixtures are being used or draining at the same time? |
#2 |
My guess is without the 2" line that should be there it my suck the water out of the trap as it was draining.
#3 |
Special User
Lav sink is 1 DFU (Drain Fixture Unit):
http://www.engineeringtoolbox.com/dr...es-d_1077.html Looks like 1 1/2" pipe can support up to 3 DFU: http://www.engineeringtoolbox.com/fi...es-d_1104.html So on the face of it, 3 bathroom sinks on a 1 1/2" drain might indeed be legal. However there may be other restrictions that apply that are in the text of the code, but not mentioned in the above table... so it's not a slam-dunk. Plus you're in Canada, dunno what is code up there.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk. |
#4 |
call me E
Local codes play a part in how many DFU's a pipe will handle. Vertical pipes generally allow more then horizontal too.
I would not put 3 lavs on a 1.5" pipe. And I would not use a sanitary cross- another code violation- at least for me
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
#5 |
Doing it myself
To further add to the code ruling on this issue (UPC Based response) :
704.2 Two fixtures set back to back or side by side within gthe distance allowed between a trap and it's vent may be served by a single vertical drainage pipe provided that each fixture wastes separately into an approved double fixture fitting having inlet openings at the same level. 706.2 ..... No fitting having more than one inlet at the same level shall be used unless such fitting is constructed so that the discharge from one inlet cannot readily enter any other inlet. Double sanitary tees may be used when the barrel of the fitting is at least two pipe sizes larger than the largest inlet......... Also agree with above comments about 1-1/2" drain being too much for 3 lavatories.
Journeyman Plumber |
| The Following User Says Thank You to Alan For This Useful Post: | TheEplumber (12-20-2012) |
#6 |
I appreciate the replies.
What would be the consequences of an overloaded drain? |
#7 |
Master Plumber
slow draining when multiple sinks in use. ger gulling, possible trap siphon. look don't knock yourself out use the correct combination on the drains you'll be alright. unless its inspected work.
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#8 | |
Overloaded Vertical DrainQuote:
So would I want the double fixture fitting above the t fitting? I can only find the double in a 2 x 1 1/2 x 1 1/2 x 1 1/2 so a reducing bushing would be necessary? |
#9 |
Master Plumber
1 1/2 double sanitary tee. they make m... on the top use a 1 1/2 (street) sanitary tee. slips into the hub. 2 inch will take up to much space between the arms. be careful that fitting in the picture is a combo not a sanitary
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Javiles; 12-21-2012 at 01:58 PM. |
#10 |
1 1/2 would be to small...consequences would be its done wrong so it will drain slow ....Iam sure you don't want that because you came to this site for the answer....you now have it....good luck ben sr
#11 | |
Master Plumber
| Display Modes | |
| Connecting shower drain to toilet drain | Liv | Plumbing | 10 | 04-17-2013 11:53 PM |
| Avoiding a frozen paver drain | BrandonC_1972 | Plumbing | 2 | 04-28-2012 10:11 AM |
| How to combine radon mitigation with drain tile/window wells? | toddmanqa | Plumbing | 4 | 03-30-2012 08:16 PM |
| Sink drain leaking, question | bergerdude | Plumbing | 3 | 03-27-2011 01:43 PM |
| relocating washer drain | idodishez | Plumbing | 7 | 04-21-2009 09:36 PM |
