Overflowing Washer Drain Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-26-2010, 07:08 PM   #1
overflowing washer drain pipe?
There are no clogs on drain line or vent, but as I installed a new washing machine the water starts overflowing out of the drain pipe. What could be wrong? When I pour water directly from a water hose it drains well. But when I place the washing macine drain hose the water doesn't go down fast enough. help!
mcasso is offline   Reply With Quote
Old 07-26-2010, 07:55 PM   #2
Rewards Points: 1,910
It's got to be either the vent or drain partially blocked or undersized.
Old 07-26-2010, 08:13 PM   #3
The new washing machines have more powerful pumps. This makes the old 1-1/2" drains too small. New Codes are calling for 2" drain lines to be able to keep up.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
Washer drain pipe and adding a utility sink lubyone1 Plumbing 5 07-09-2010 11:56 PM
Front-loading Washer Drain cbeingessner Plumbing 13 09-12-2009 10:58 AM
Major drain issue... what is this pipe? moneymgmt Plumbing 9 08-04-2009 11:53 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 11:35 PM
