| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Plumbing and Drain Tips for Bathroom Installation
by Expert Village
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
How to Thaw Frozen Pipes
by eHow.com
If you live in a part of the country where the temperature gets down below freezing, you just might run into the problem of having your water or drain pipes freeze. As long as you’re home (and not off vacationing somewhere warm) you can usually fix... Read More »
Stop Bath for Developing Film
by Expert Village
My ten minutes are up, and what I'm going to do with my developer is I'm just going to pour it down the drain. Developer and stop bath are really technically the only things you should pour down the drain. Don't ever pour your fix down the drain. Once... Read More »
3-Wood Golf Swing
by Expert Village
We're using a three-wood; you can see, it's got about a fifteen degrees of loft on it. At the pro level the ball can be hit at 250 or 270. It can hit pretty far. Although, for the recreational player, the good local player and for the up and coming... Read More »
How to Install a Dishwasher: Part 1
by Expert Village
I’m Lee. I have a degree in architecture and about ten years construction experience, and we’re installing a new dishwasher. The water inlet, which is, everything’s located on the bottom. You just want to take some Teflon tape and... Read More »
