Over Or Under A Perforated Drainage Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-04-2013, 02:44 PM   #1
Over or under a perforated drainage pipe?
I want to run a 2" DWV pipe from a sewage pump to a septic tank but there is a perforated drainage pipe (coming from the septic tank running to the leach field) crossing where I want to run the pipe.
The drainage pipe is 12" down. Should I run my pipe over or under or do I need to find a different solution?
KingCrabLegs is offline   Reply With Quote
Old 07-04-2013, 02:53 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 436
Don't know if you can do it but- I'd tie the 2" into the building drain before it exits the house. That's the proper way.
Right now, you are digging through your drain field and it's best to leave it undisturbed.
Old 07-04-2013, 03:21 PM   #3
I'm plumbing from an outbuilding to the septic system. I've tied in the 2" line from the outbuilding to the pipe from the house right before it enters the septic tank.
The problem is, to get the 2" pipe from the sewage pump/basin for the outbuilding to the tie-in, I have to cross where the drainage pipe runs from the septic tank to the leach field. If I absolutely needed to I could probably go the other way around the septic tank to avoid the drainage pipe but that's a lot more trench and more complicated run
It's much simpler if I can just go over or under this one drainage pipe.
Old 07-04-2013, 04:36 PM   #4
jproffer's Avatar
Rewards Points: 706
I can't imagine that over or under would matter for DWV. Feed lines would need to be deeper than that, but not DWV necessarily.
Flip a coin...
jproffer is offline   Reply With Quote
Old 07-04-2013, 05:30 PM   #5
Rewards Points: 582
its being pumped so its your call which would make your life eaiser...ben sr
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 09:00 AM
Backfill above 110mm drainage pipe sib321 Building & Construction 0 08-13-2012 04:21 AM
Rigid perforated pipe - holes up or down? burnt03 Landscaping & Lawn Care 5 08-04-2012 08:30 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
The IPGC Drainage Pipe agster97 Landscaping & Lawn Care 0 07-09-2009 01:05 AM
