-   -   Over or under a perforated drainage pipe? (http://www.diychatroom.com/f7/over-under-perforated-drainage-pipe-183047/)
KingCrabLegs 07-04-2013 01:44 PM
I want to run a 2" DWV pipe from a sewage pump to a septic tank but there is a perforated drainage pipe (coming from the septic tank running to the leach field) crossing where I want to run the pipe.
The drainage pipe is 12" down. Should I run my pipe over or under or do I need to find a different solution?
TheEplumber 07-04-2013 01:53 PM
199 Attachment(s)
Don't know if you can do it but- I'd tie the 2" into the building drain before it exits the house. That's the proper way.
Right now, you are digging through your drain field and it's best to leave it undisturbed.
KingCrabLegs 07-04-2013 02:21 PM
I'm plumbing from an outbuilding to the septic system. I've tied in the 2" line from the outbuilding to the pipe from the house right before it enters the septic tank.
The problem is, to get the 2" pipe from the sewage pump/basin for the outbuilding to the tie-in, I have to cross where the drainage pipe runs from the septic tank to the leach field. If I absolutely needed to I could probably go the other way around the septic tank to avoid the drainage pipe but that's a lot more trench and more complicated run
It's much simpler if I can just go over or under this one drainage pipe.
jproffer 07-04-2013 03:36 PM
I can't imagine that over or under would matter for DWV. Feed lines would need to be deeper than that, but not DWV necessarily.
Flip a coin...
ben's plumbing 07-04-2013 04:30 PM
its being pumped so its your call which would make your life eaiser...ben sr
