Outside Water Won't Turn On - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2008, 06:45 PM   #1
Unhappy
outside water won't turn on
we tried the inside valve nothing. what could be wrong. any help or suggestions please
viqueen is offline   Reply With Quote
Old 05-14-2008, 09:08 PM   #2
Custom Cabinet Maker
Replace the hose bib. Sounds like the washer inside is frozen to the seat and the screw holding said washer is broken off.Depending where you live replace it with frostfree if youlive in cold climate
skymaster is offline   Reply With Quote
Old 05-17-2008, 07:31 PM   #3
hehe could be anything I would trace the line that the hose bib is on back to the next valve and make sure that it is on before replacing anything. sometimes (me included) people shut the second valve off in winter incase of freezing (thus a flood).
pipefitter is offline   Reply With Quote
Old 05-17-2008, 08:18 PM   #4
PIPEFITTER: Awwwwwwwwwwww Come on. " make sure the water is off?}
No fun How can we get the answer to the great question" HOW LONG CAN HE TREAD WATER) If the water is OFF ROFLOL
Water Mystery - Sump Pump Set Right? robertr4836 General DIY Discussions 4 02-13-2008 02:32 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 02:17 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
