Outside Water System Box Clunking - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2008, 08:37 AM   #1
Outside water system box clunking
I have a well, which is located on the property to the front of the house. The drainfield is located to the rear of the house. Since the drainfield is slightly uphill, there is also a pump in the system. There is a large plastic box (see picture) attached to the rear of the house, on the outside of the wall from where the well tank is (it is in the crawlspace, under the house). There are two pipes attached to the bottom of this box and I assume one runs to the well tank, the other to the drainfield pump. I could be wrong, however, as one looks like electrical conduit to me.
I am finding more and more that when there is wastewater of volume (such as the dishwasher or washing machine) being moved to the drainfield that there are several loud thumping/clunking noises coming from this box in a series. I would liken it to a hot water radiator clanging except everything I have is plastic, not metal, but it is the same concept in my mind. I have no idea what the box is. I assume that since this noise is new (I have been here three years and have only started hearing the noise in the past year or less) it is not a good sign. I also only hear the noise when there is wastewater of volume, not simply when a faucet is turned on or the shower is run.
Anyone have any idea of what is failing and what I should do about it?
ruralhomeowner is offline   Reply With Quote
Old 08-15-2008, 10:10 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Did you try opening the box to see whats inside?
Journeyman Plumber
Old 08-15-2008, 10:43 AM   #3
As I suspected, there is a pump box inside. So does that mean the pump is going bad/has gone bad? It's only 8 years old according to the label on the pump box.
Old 08-15-2008, 10:29 PM   #4
Doing it myself
Alan's Avatar
what kind of pump is it? Can you take a picture?
Exactly how big is the housing pictured above?
Its kind of hard to gauge exactly what could be in that box without some sort of reference for size, but a picture of whats inside would be even better, including if possible, a picture of the pump's data plate.
Journeyman Plumber
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 08:31 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
boiler / Over-pressurizing cparke HVAC 1 05-21-2008 06:54 AM
I added a radiator to my system and now need to know how to refill enough water memovox2 HVAC 21 01-30-2008 09:27 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
