Outside Water Boiler Shutdown - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2009, 09:03 PM   #1
Outside water boiler shutdown
I have a outside woodburner boiler tied into my oil fired boiler in my home. With winter coming to an end. I will be shuting down my wood burner, I would like to shutdown my oil boiler also. Can I simply just shut them down or do I need to drain the whole system? I don't want to run the boiler just just to maintain a boiler temp. I am worried the oil boiler might rust, my wood burner is made of stainless steel. I installed it two years ago and added a anti-rust agent then. Any suggestions?
hillardl is offline   Reply With Quote
Old 03-19-2009, 07:41 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,706
Ayuh,...
Just Flip the switch to Off...
Draining the boiler will create Way more problems than just turning the power Off...
Old 03-20-2009, 05:27 PM   #3
Thanks for your help
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Hot water boiler furnace-insufficient heat Nashman HVAC 2 11-06-2011 06:15 PM
hot water boiler heating raineywillow HVAC 3 12-26-2008 07:51 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
