Outside Water Backflow Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-26-2012, 05:49 PM   #1
outside water backflow valve
Every time I do my laundry the outside water flapper value pushes out and the water runs until i push the value in. How can i stop this form happening?
tesneath is offline   Reply With Quote
Old 07-26-2012, 05:51 PM   #2
Rewards Points: 582
The Following User Says Thank You to ben's plumbing For This Useful Post:
tesneath (07-26-2012)
Old 07-26-2012, 05:53 PM   #3
water value
every time i do laundry a water flapper valve goes off outside and the water runs constantly until I push in on the valve. How can i stop this from happening every time i do laundry?
Old 07-26-2012, 05:53 PM   #4
DIY staff
Rewards Points: 7,174
Not familiar with the valve you are describing---what country are you in?
Can you post a picture of it?
Old 07-26-2012, 06:04 PM   #5
water value
U.S. West Palm Beach Florida
Old 07-26-2012, 06:53 PM   #6
Rewards Points: 1,536
The washing machine starts and stops drawing water so abruptly that when it stops drawing, there is a moment of high pressure that pushes the flapper valve open. I suspect that something is either broken or worn out or missing or jammed at the outside valve; it should not open by itself and stay open.
Water hammer arrestors can be purchased that screw onto the back of the washing machine where the hoses attach and they cushion the shock wave.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 07-26-2012, 07:22 PM   #7
water value
Thanks AllenJ thats what i think too, i'll check it out
Old 07-26-2012, 08:58 PM   #8
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Still in the dark about what a water flapper valve is.
Journeyman Plumber
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
