-   -   Outside spigot question... (http://www.diychatroom.com/f7/outside-spigot-question-100280/)
carpenter981 04-01-2011 09:54 PM
Ive got an outside water spigot on the back of my house. It has a discharge looking CPVC drain about 8 inches to the right of it. The spigot is right outside of the basement. Inside the basement there are drop ceilings to where I have access to the shut off valve for that spigot.
http://i61.photobucket.com/albums/h4...8/9c3619f4.jpg
When the shut off valve is open and the spigot is off, the discharge pipe leaks a pretty good bit. When I turn the spigot on, the leak from the discharge pipe stops. When I turn the shut off valve off, the discharge leak stops.
In the drop ceiling where the shut off valve is, there is no CPVC anywhere going to that discharge pipe. I have no idea where it is coming from. It is definitely not connected to the hot water heater. I can not find a connection for it to be from the AC or furnace.
My question is, what is this pipe, why is it leaking, and what can I do to fix it??????
havalife 04-01-2011 11:04 PM
You have 2 pipes and you can find out where they go. Re-read what you are asking to be answereq.
carpenter981 04-01-2011 11:07 PM
What? Im trying to find out what that PVC pipe to the right of the spigot is...I can not find where it is coming from...
VIPlumber 04-01-2011 11:32 PM
Can I ask why you are so certain that it's not coming from the T&P valve on your hot water heater? That's the only thing that comes to mind seeing piping like that.
carpenter981 04-01-2011 11:37 PM
Because I traced the CPVC line coming off the T&P through the drop ceilings, going towards the outside of the house. It then 90* down and out another similar pipe 30ft away from the pipe in question
VIPlumber 04-01-2011 11:49 PM
Fair enough then. I'll admit I'm curious as to what it could be.
havalife 04-02-2011 12:02 AM
Sorry but I will have to say take the drywall off the wall inside so you can see what is in the wall, the pic does not help.
Jackofall1 04-02-2011 01:30 AM
There are strict rules regarding the T&P relief valve from the HW tank, and you are way beyond what is allowed, the potential of this causing a real problem in the event of a true need to relieve is extreemly dangerous, you need to change this for your own safety.
Mark
COLDIRON 04-02-2011 05:57 AM
Relax sit down have something to drink think, think, think about it.
Your there not us it's your house I am sure you can find it just don't give up and keep looking.
It's
a. Water Heater T/P discharge
b. A/C condensate drain
c. Drain back valve for winterizing the pipes.
d. Sump discharge.
Anybody????
Thurman 04-02-2011 11:33 AM
Wild guess here: Do you live in a cold climate where freezing weather is common? You're outside hose bibb may be a "frost-proof" type with the actual valve seat located inside the walled area. There may be a drain attached to the housing of the frost-proof faucet housing which allows all water to drain to prevent the housing from freezing up in winter and causing cracking. I've seen these in Alaska. I also notice you have a "Back-flow Preventer" on the faucet which is probably required by local code in your area.
carpenter981 04-02-2011 12:35 PM
Im actually in GA also, Gwinnett County.
I still havent figured it out, Ive turned the pressure reducing valve into the house down a little hoping it would stop it but it hasnt. I dont have a gauge to check it but it did lower the pressure in the house a little...
carpenter981 04-02-2011 12:38 PM
Mark
Show me a link to the code where it states that mine is against code...
Jackofall1 04-02-2011 01:08 PM
You know instead of challenging this, why wouldn't you look it up,
First thing I see is, if in fact this is T&P relief piping, the piping appears to have been reduced to 1/2" Dia **note I say appears***,
2nd - I can't see the other end I can't really say but you might want to look at, the fact that if again this is a T&P drain there has to be an air gap in the room that this piping originates from,
3rd - the discharge in a manner that does not cause personal injury or structural damage......I see a possible scald issue by its location.
4th - I would say that is incorrect piping material for T&P relief piping.
Your place, your decision, hope it doesn't bite you in the rear end if something was to happen
Over and out
Mark
Clutchcargo 04-02-2011 01:24 PM
63 Attachment(s)
To the OP,
Where is your washing machine and does it have a drain pan?
carpenter981 04-02-2011 01:55 PM
Over and out
Mark
I can GUARANTEE you this has nothing to do with the T&P relief for the water heater. I can trace the T&P release from start to finish and it is nowhere near the pipe in question.
I tried to search for what you are saying is against code and I found nothing. Everything I found states that my piping is to code. This is why I asked you to show me other wise.
