Outside Spigot Leaks Into Crawlspace Only With Hose Attached - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2011, 08:04 PM   #1
Outside spigot leaks into crawlspace only with hose attached
After turning on our garden hose for the first time of the season, my husband went in the house while I was outside and heard water spraying. He went into basement and peeked into the crawlspace over the wall, and saw water "spraying". When we turned off the spigot/hose, it stopped.
We have since discovered that it only sprays like this if the hose is attached outside. If nothing is attached to the spigot, it does not leak/spray - regardless of being turned on or off.
This doesn't make any logical sense to us. Any ideas?
(ETA: No we did not turn off the water to this for the winter. So it likely froze and that may have caused an issue.)
amandat37 is offline   Reply With Quote
Old 04-12-2011, 06:32 AM   #2
I am guessing..........it is a freeze proof spigot, the kind that has the actual washer seat/cutoff 9-12" inside the house. It froze/cracked enough that it only leaks with pressure on it. With the faucet open, with no hose, not enough pressure to force the crack open.
The Following User Says Thank You to Just Bill For This Useful Post:
Thurman (04-12-2011)
Frozen outside faucet leaks -> Hose left attached k6trouble Plumbing 13 07-01-2013 11:29 AM
conditioned crawlspace fan albertpinto HVAC 4 12-27-2010 04:46 AM
garden hose water spillage: damage to pipes, huge water bill? cluelessDIYer Plumbing 5 06-26-2010 11:42 AM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 07:49 AM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
