Outside Spigot, Faucet Or Hose Bib Thing Replce Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-24-2009, 01:59 PM   #1
Outside Spigot, faucet or hose bib thing replce help
Hello~! I have an outside spigot that is leaking. Here is the photo. I've done research and I've read to just turn the spigot with a wrench and it should come off, but I haven't seen any that look like mine. I've also tried and it doesnt budge.
Do I have the kind that I can just turn or do I have to cut and all that? I cannot get behind it b.c. everything is in the wall.
Thank you~!
KPak1984 is offline   Reply With Quote
Old 05-24-2009, 02:18 PM   #2
If it is just leaking why do you need to remove it? Take the screw out and remove the handle, then remove the packing nut, pull out the stem and replace the washer on the end of the stem. Reinstall.
hayewe farm is offline   Reply With Quote
Old 05-24-2009, 02:31 PM   #3
oooooooooo...is that what i'm supposed to do? geez. oky i'll go try that. thank you!
Old 05-24-2009, 02:41 PM   #4
the Musigician
DangerMouse's Avatar
if it's in such bad shape inside (corroded/pitted. etc.) that replacement is necessary, grab a pipe wrench, position the jaws over the USA on each side and rotate CCW, it will unscrew.
DM
Old 05-24-2009, 02:44 PM   #5
the Musigician
be sure to take the old one with you to replace too, it looks like you have a check valve or something on that unit.
DM
Old 05-24-2009, 09:14 PM   #6
Rewards Points: 1,088
The handle is usually keyed into the stem. What would you do if it's corroded together?
handy man88 is offline   Reply With Quote
Old 05-24-2009, 09:27 PM   #7
PB blaster or WD45 and tap alternately on each side of the handle. Rocking the handle usually will break it loose.
Old 05-24-2009, 09:29 PM   #8
GC/Master Plumber/Mech
Rewards Points: 560
I'd replace the whole exteerior hydrant. That is and older hydrant because that "thingy on the end" is a vaccum break and most of todays hydrants have that anti-siphon break built into the hydrant.
If this in a crawlspace slide in and remove at the connection. Please don't just try to CCW turn the hydrant because I have had to go and repair the line that feeds the hydrant from being twisted.
just my $.02.....replace
Strange faucet (hose bibb) pjpjpjpj Plumbing 7 08-24-2009 08:12 AM
ouside hose faucet is LIVE!!! rdmccaw Electrical 20 04-23-2008 06:16 PM
Installing a Hot / Cold Water Spigot dc2295 Plumbing 1 02-25-2008 06:10 PM
Aerator for Hose Faucet prowler 13 Plumbing 2 12-17-2007 08:17 AM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 01:27 AM
