Outside Basement Steps Drain Clog - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-21-2010, 08:09 PM   #1
Outside basement steps drain clog
Hi all. Looking for a little advice. I have a clog in the drain at the bottom of the exterior steps to my basement. It's causing flooding in the basement whenever it rains. It seems to be clogged with dirt, sand, leaves, and some construction material i.e. joint compound or grout or something.
I've tried snaking it, but the snake just won't go down past the first bend. I've tried putting a hose down and surrounding it with a wet towel to see if I could force it down that way. I've tried using one of those rubber bladders, but it burst inside the pipe. I've also picked as much gunk out as I could out with a drain grabber tool.
Any thoughts before I call a plumber? Thanks!
--Chris
sillyboy22 is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
levelling basement floor around drain jhaug Flooring 0 02-04-2010 05:47 PM
Basement bathroom sink drain line on a slight upwards slope an issue? dtran Plumbing 7 01-10-2010 06:05 PM
Basement floor drain causing me anxiety tondar Plumbing 1 06-21-2009 09:06 AM
pump setup drain in the basement? jimmy21 Plumbing 4 07-27-2008 07:47 PM
