Old 10-18-2009, 09:54 PM   #1
outdoor water heater
has anyone had experience with outdoor water heaters, for space and venting problems i really wanted to try one, it supposed to have freeze protection to 20 below, my question is how are these in cold climates i live in pa and we do get at least 1 or 2 months of really cold weather, i only found 1 article of someone in utah installing them, i am going to use heat tape and insulation for the piping but my concern is the unit itself, what additional protection for the unit can i use. the heater is the rheem 53xp any advice would be greatly appreciated.
sixguns69 is offline   Reply With Quote
Old 10-19-2009, 09:58 AM   #2
As long as the heater is turned on and operating properly, it won't freeze.
You could wrap the outside in an approved insulation blanket to reduce energy consumption keeping the water hot enough.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 10-19-2009, 01:56 PM   #3
philcjr's Avatar
From pg. 7 of the installation instructions for the Rheem 53, it says:
● The water heater and water lines should
be protected from exposure to freezing
temperatures.
philcjr is offline   Reply With Quote
Old 10-19-2009, 07:45 PM   #4
i seen that too, i talked directly to a rheem tech, and he told me the unit by itself, as long as it doesnt get colder than 30 below with the wind chill the unit will not freeze as long as there is power, he just told me to get a battery backup for power outages the unit uses 2 amps for the freeze protection. i thought about making an insulated cover for it for a little extra protection or get the recessed box rheem makes.
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
