Outdoor Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-15-2013, 11:44 AM   #1
Rewards Points: 27
Outdoor valves
I needed to replace my outdoor faucet as it cracked over the winter, even though I was sure there was no water in it.
I have a 3/4" underground sprinkler system and also a 1/2" garden hose.
So I have put in the main 3/4 inch faucet and I'm now trying to think if there is a better way than soldering together the rest of it.
So what I need is the 3/4" x 3/4 x 1/2 setup with the main valve and then 2 more valves for the sprinkler and hose.
Does anyone have any good ideas for this?
blott0 is offline   Reply With Quote
Old 05-15-2013, 12:19 PM   #2
Rewards Points: 91
1. Have a shut off in the basment or inside the house
2. Buy fitting pictured and sweat it to the supply pipe.
3. Get one of these for the sprinkler and have it come out of the top of the new Tee you just bough. http://www.febcoonline.com/Products/76
4. Thread in a new faucet fitting.
5. Bolt everything tight
Now you can blow out the sprinkler lines through the faucet fitting. and also leave the faucet open in the winter (with the one inside the house closed)
tjfslaughter is offline   Reply With Quote
Old 05-15-2013, 02:34 PM   #3
Rewards Points: 27
this link doesn't show up, is it a backflow preventer? the one you screw on to your faucet threads?
Old 05-15-2013, 02:46 PM   #4
Rewards Points: 91
It's a back flow that has 3/4 pipe thread the pipe thread needs to face upward.
Old 05-15-2013, 02:56 PM   #5
Rewards Points: 27
like this
Old 05-15-2013, 03:59 PM   #6
Rewards Points: 91
like this
I would not trust this to protect my family from ingesting the chemicals I put on my lawn.
Old 05-15-2013, 04:35 PM   #7
Rewards Points: 27
I am going to put one of these inside
