| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How a Sprinkler Head Works
by Expert Village
Hi I'm Fernando with Expert Village going over how a sprinkler head actually works and as you can see this sprinkler is connected to the pvc piping. When the pressure comes from the valve which is the water rushes in and fills up the piping it then goes... Read More »
How to Choose Irrigation Valves
by eHow.com
Irrigation systems comprise a number of elements, including valves. A shut-off valve, generally located as close to the irrigation system's water source as possible, lets you manually turn off the water to make adjustment to your system. Control valves... Read More »
Dig a Hole for Your Barbeque Pit
by Expert Village
Hi! I'm Mark Sullivan for Expert Village and today, we are going to learn how to build a barbecue pit. Now we have selected the proper location for our barbecue pit and we are going to dig a hole approximately two and half feet across by two and half... Read More »
How to Find a Head Gasket Cover
by Expert Village
Hi my name is Nate McCullough on behalf of expertvillage.com. In this clip we are going to talk about what a valve cover is and where they are located. The valve cover is this component right here. It is a cap pretty much for the top of the engine. There... Read More »
How to Check Tire Pressure
by Expert Village
Hi! This is John on behalf of expertvillage.com. In this video clip, I will show you how to check for proper tire pressure. The first thing you need to do is check to see what the tire pressure should be and if you take a look at the inside of your... Read More »
